Carrera Sport wheel in an 86 911 ?
Hi
Does anyone know if the 'Fat' Carrera Sport Steering wheel will fit an 1986 911 ? or would I need to modify something ? I know the 84' 911's came with the three spoke wheel. Thanks
911 Coupe |
I know the 380mm Carrera Sport wheel can fit an SC and an 84 Carrera.
Can anyone tell me if there is a difference between the steering column where it meets the steering wheel on an early 84 Carrera and the 1986 Carrera which has the standard 4 spoke Carrera wheel ?
911 Coupe |
Paradigm Short Shifter
Yes it will fit.
Michael |
cycling has-been
my 85 came had 4 spoke, but also included a factory (1 1/2"?) spacer, so when I replaced with the sport wheel the reach was increased (for me, a good thing). Check your existing wheel to see if it has the extender installed - the spacer will not swap to a three spoke. Otherwise a plug-and-play swap. Both cars have the same column, splines and shaft. Bill K
73 911T MFI, 76 912E, 77 Turbo Carrera |
Make sure you get a 911 wheel.
There are people on ebay and even on here that are selling 944 3-spoke wheels that say they work on a 911. They look identical but will NOT fit on a 911 - splines are VW/Audi splines, not 911. |
CS version for the 944 ?
Thanks for the info:
So is there a 'Fat' Carrera Sport 380mm version for the 944 ? if so do you know the different P/N so i can check.
911 Coupe |
Thanks for the feedback. The ink below shows the wheel I'm asking about, and that I want to put in the '86 911 This is the 'Fat' 380mm version of the 3 spoke
FS: 1974 - 1977 Carrera Sport Thick Rimmed Steering Wheel
911 Coupe |
Here are photos of a sport wheel that I just had recovered for my '74:
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo http://www.pelicanparts.com/gallery/fintstone/ "The problem with socialism is that you eventually run out of other people's money" Some are born free. Some have freedom thrust upon them. Others simply surrender |
Here is a sport wheel that I just had recovered for my '74:
Here a a few more:
Very nice indeed Flintstone ! Please post a pic when you have it in the car.
911 Coupe |
Hey Fint!...That is gorgeous! Did you do that or shop? If a shop, please post who it is.
'17 Cayenne |
Bought the core from a Pelican a couple of weeks ago...sent it to Dallas Custom Steering Wheel based on a recommendation on Pelican. Not cheap, but a two day turn around and apparently high quality work.
Thanks! I just pinged them for more info.
'17 Cayenne |
I had Dallas Custom Wheel do my three spoke last year, came out great with the extra thickness. Warning: The price has gone up dramatically...
Kurt |
abides.
Anyone mind sharing what they paid for the recovering service?
Graham 1984 Carrera Targa |
I emailed them this morning and got a quick reply. It goes for about $340, including return shipping.
'17 Cayenne |
abides.
Thanks Hal. That seems to be a pretty typical price... Autobahn was similar when I emailed them a while back.
Better photo:
