oil pressure
Is there away to check the oil pressure gauge, mine jumps around, could be bad sensor or the gauge is bad,any ideas,oil is full, Thanks Norm
Old 09-06-2010, 03:53 PM
dshepp806's Avatar
Back when I first saw this on my '89, I immediately installed a new pressure sender,..It gave me a bit more accuracy but not textbook. Continuity to the gauge was quite good.....so, I left it at it it were.
Thinking about seninf the gauge out for checks/repairs....I'd really like to see the proper ratios of RPM/Pressure.
A gauge was used to meaure (quantify) the actual pressures vs. RPMS and all was ok (I slept better)...now I want the gauge to dance correctly.
Have you a Bentley?Should dance ~) 1K RPM per 1 PSI. 170-5 (for my '89) shows: 4.5 BAR (59PSI) at 5K RPMs (at ~194 degrees F/90 degrees C).
For now,..she's telling me all I need to know!
Connection points need to be solid from sender to the gauge,..ground included....check those first. (a grounding of the sender line (at the pressure sender connection) should give you full scale at the meter (intrument)>
Best,
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 09-06-2010, 04:05 PM
Thanks Doyle, I will check the wireing tomorrow. Norm
Old 09-06-2010, 04:16 PM
