BoxsterGT's Avatar
Porsche Crest 930 Fuel Hose Assys
I just had a request for the (3) fuel hose assys on a 78 930 that go from the tunnel to the pump to the engine & back to the tunnel.
It seems that only one is available at Porsche.
The lines in question are ........
Supply from tunnel to Pump:
Pressure line from pump:
and the return hose from the top of the CIS back to the tunnel:
This last hose I just made up, but I would have to order the correct 180 deg fittings to make the other hose assys for this application.
I have lots of fittings, even some 180's but not this size.
My question is........Is there any demand to justify the expense & time delay to special order the 180 deg fittings just to make up a few lines?
Anyone else need something similar for their 911?
Len at autosportengineering dot com
Old 08-17-2009, 09:09 AM
BoxsterGT's Avatar
Porsche Crest
Update: Just ckd w Porsche, and the top two lines w the 180 deg ends are now available. The bottom (return) line is s/o Germany, but this is the one we have been able to make up.
So...Emergency over for now.
Old 08-18-2009, 07:51 AM
BoxsterGT's Avatar
Porsche Crest
Update,
I now have the 180's in stock, so I can make up hoses w the 180 deg fitting.........
Also have the Banjo hose ends but no photo yet.
Len
Old 09-07-2010, 12:35 PM
