Fan pulley nut is stuck on my '73 T, broke my fan pulley tool!
Hi there,
Someone over-torqued the nut that holds the fan belt pulley on. I used a block of wood to make sure the fan pulley tool was held still and to let me put more leverage on the 24mm ratchet. Result,: the of the prongs on the fan pulley tool sheared off...doh!
any ideas for removing an over-torqued fan pulley nut? Do I dare use a dremel tool to remove it?
Old 09-08-2010, 04:38 PM
fastfredracing's Avatar
I believe that you can use an impact gun with an extension, and swivel socket . Will blast it right off.
No left turn un stoned
Old 09-08-2010, 05:29 PM
Friend of Warren
Yep impact wrench. Just go to your local garage and pay a couple of dollars to zip it off and then tighten down to correct torque.
Kurt V
Old 09-08-2010, 06:24 PM
HarryD's Avatar
Sorry for the Bad luck. Hopefully it is just too tight.
Once you get the nut off, count the shims. You SHOULD have 6 total. If not, your shaft may be damaged as well.
When you reassemble, use NEW shims and consider a new cup washer as well. I suspect the old ones may be a bit distorted.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 09-08-2010, 10:01 PM
GrantG's Avatar
What is the torque spec?
2022 GT3 Manual, 73 Carrera RS 2.9 Twin-Plug MFI Carbon Fiber Replica
Former: 18 GT3 Manual,16 Cayman GT4, 73 911S, Two 951S's, 996 C2, 993 C2, BMW 635CSi Euro, Ferrari 550 Maranello, 06 Evo IX w/ many mods
Old 09-08-2010, 10:05 PM
