Red face Sometimes ya gotta laugh about it
So on that sunny day when I couldn't get the Targa top off because the latches broke, here's what else happened.
1. Driving and noticed the passenger headlight is on but much more dim than the driver side. Interesting since historically lights have just burned out on me.
Could this be a bad bulb or does the fact that it didn't go out entirely indicate some other electrical issue such as contacts worn, dirty, or wet? It had been raining before.
2. Tach continues to get stuck. OK that one was old and is probably just the tach needing to be fixed or replaced.
3. The killer. I'm almost home and I see this flash in front of my eyes, then feel a crash on my right arm which was reaching for the shifter. What the hell was that? I look to my rear view mirror to check traffic as a reflex and there is no mirror! The rear view mirror fell off the window. Apparently the PO used a cheap glue to hold it on. Guess I will need to epoxy it or something.
I just had to laugh at my fun day of motoring.
Tim
'81 Porsche 911SC Targa
'00 Audi A6 4.2
'99 Ellsworth Truth
'02 Taylor with new Tru Temper S3 and carbon fiber!
Old 01-08-2002, 04:32 PM
one of gods prototypes
bell's Avatar
the headlight problem is most likely a corroded ground wire. it's probably corroded right at the plug where it attatches to the headlight bulb, this happened to mine, i ended up replacing the socket because the actual terminal where the wire connects is what was corroded.
bell
85'911 targa
Old 01-08-2002, 04:38 PM
stormcrow's Avatar
Boy, you better be careful about what you post. You are beginning to make it sound like your p-car went British.
Old 01-08-2002, 05:12 PM
Cool
Steve,
Did I say "motoring"? Sorry, I meant DRIVING!
Tim
'00 Audi A6 4.2
'99 Ellsworth Truth
Old 01-08-2002, 05:16 PM
stormcrow's Avatar
Whew, you scared me there for a moment. I guess I had a Triumph moment when I read your post. I used to own a TR-7 awhile back - need I say more.
Old 01-08-2002, 05:24 PM
steve911's Avatar
Tim--
its days like that where I just park the car and put it away - no telling what ELSE might happen. hope all fixes are easily done.
can't wait for another bay area 911 gathering!
My '85 911 Targa ** Hand painted center caps for sale here
RIP Warren
PCA & Rennlist member
Old 01-08-2002, 05:25 PM
I don't believe that Lucas was ever a subcontractor for Porsche...but, wait a minute....it IS an SC.... You'd best get those nasties squared away lest you embarrass the SCWDP.
OK, OK, just kidding....I don't need to be on the hit list of the SCWDP thugs. I'd like to keep my kneecaps intact
Old 01-08-2002, 08:24 PM
Those are the days when your horoscope says .."Don't get out of bed today" but its too late ya had to get up to get the paper to read the horoscope! Trouble's already started! Sort of like.."Experience is what you get right after you need it"!
Howie
79SC
Old 01-09-2002, 11:55 PM
Senior Member
Jdub's Avatar
No, your Porsche won't blow the head gasket like the TR7 would...
Your headlight is the ground. Anytime you get dim lights it is invariably a ground that is trying to work but cannot as rust or corrosion has finally killed the contact. I'd take the time to pull the whole assembley and wax the inside of the headlight bucket area after cleaning out all of the dirt you will find in there.
John
'78 Targa in Minerva Blue
Old 01-10-2002, 08:21 AM
