| Registered User Join Date: Jul 2011 Location: Indianapolis, IN
				964 convertible top copper washer substitute?
			Hi all, The top on my 964 cab started "laboring" upon open & close. After looking further into the problem, I found that the copper washers (999 025 254 10) seated between the motor and convertible top drive arm were worn (one was actually torn!). It seems like everyone wants ~$25/prt for the washers. This seems outrageous to me. Does anyone know of a substitute? Thanks in advance! -john | ||
|  09-09-2011, 04:15 PM |
| Registered Join Date: Sep 2009 Location: North of You
			Dimensions? There will be lots of other places to buy washers. McMaster Carr maybe?
				__________________ "A machine you build yourself is a vote for a different way of life. There are things you have to earn with your hands." | ||
|  09-09-2011, 06:19 PM |
			the washer is: Thickness = 0.060" ID = 1.125" OD = 2.0" I checked McMaster Carr and i really don't see anything in brass or copper with an ID big enough... Did anyone else have any luck? | ||
|  09-10-2011, 11:28 AM |
			Anyone think a thrust bearing would work?  This one looks to be about the right dimensions...
|  09-10-2011, 11:49 AM |
			Too good if anything. I was going to suggest a bronze washer.
|  09-10-2011, 02:54 PM |
| Registered User Join Date: Feb 2011 Location: Bellevue, Wa
			how many washers does it take? I mean....$25 is pretty cheap in the big picture, you probably wasted that much on a bottle of wine you didnt even like.....
				__________________ Ed M 86' Coupe | ||
|  09-10-2011, 03:09 PM |
