polizei's Avatar
Bosch Motronic Tuning for Turbo Carrera - questions and referral in SE PA
Hey all,
I'm nearing the end of the turbo conversion on my '87 Carrera. I've made more changes than I originally planned, and I'd really like to be sure that I'm getting the most out of my setup. I ordered a chip from Protomotive based on my setup (3.3 L cylinders with 8.0:1 compression pistons, 964 twin plug dizzy, stock carrera injectors, .7 BAR boost). I've since decided to add methanol/water injection and up the boost to 1 BAR.
From the research I've done, it sounds like there are not that many companies that customize ECUs for our cars. In fact, Protomotive and Steve Wong are the only 2 I'm aware of. I've got a few questions that I'm hoping some of you may be able to answer:
1. Is there any other data needed to customize our ECUs other than air/fuel?
2. Will Protomotive customize an ECU based on air/fuel data you send to them? Or will they only provide more cookie-cutter programming?
3. Does anyone know of a tuner near Southeast Pennsylvania that will customize ECUs for our Bosch Motronic EFI systems? If there aren't any nearby, are there any companies that will customize based on air/fuel data that I could send to them?
Thank you!
Andy - 1987 911 Carrera Coupe
Old 09-10-2010, 07:16 PM
Mocha BAP
Staylo's Avatar
Send a message via Yahoo to Staylo
Talk to Todd at Protomotive about your setup. He's worked on a lot of these custom builds and can help you through the process.
Ideally you would want some dyno time to fine tune.
Scott
71 911T Coupe 3.0 Looks stock
79 911SC Coupe 3.2ss Nothing stock
02 996 C2 Cab Mostly stock
06 955 CTTS Super P!G
Old 09-10-2010, 07:56 PM
