Caliper making creaking noise?
I just replaced my flexible brake lines with our host's SS brake lines, and renewed the fluid.
After the bleeding process, I have a nice firm pedal- but I now notice when I press down on the brake pedal that the Front RH side caliper side makes noise. Like a creak-creak-creak noise as I increase the pressure on the brake pedal. Any ideas? (86 930, if that isn't in my sig.) On Edit- somehow posted to the Engine Section- moderator please move to the 911 tech forum or the 930 board- thanks |
Sounds like it's time to buy a caliper rebuild kit.
All Mine have done that... Sully may be right if some pistons aren't working as well it could be flexing a brake disc.
| All times are GMT -8. The time now is 07:50 AM. |
