-   -   A/C Hose Routing (http://forums.pelicanparts.com/porsche-911-technical-forum/563864-c-hose-routing.html)
llangston1 09-11-2010 07:05 PM
A/C Hose Routing
Does anyone have a picture of the a/c hoses that shows the routing at the lower rear of the drivers side wheel well just below the drier? I did not take a pic of that spot and need to see how the hoses mesh with the clamps and that drain hose that is co located in that area. Does the long hose from the rear condenser come up through that rocker panel gap over that black trim plate or does it come up around the bottom of the body pan? Which way does the hose clamp that attaches to the small stud that sticks out of the corner of the body pan point: to the inside or outside of the car? Is there some trick to getting enought slack in the hoses to route them up through the clamps along the top of the fender well especially where they route behind the washer reservoir? Amy pictures or descriptions of the hose routing in this area would be greatly appreciated.
JJ 911SC 09-11-2010 07:14 PM
omming to a theater near you...
If you don't have posted info by tomorrow morning, I'll put her up and take some pics.
http://forums.pelicanparts.com/uploa...1284261202.jpg
mthomas58 09-11-2010 07:33 PM
I'm not sure if this will help you because it is a ProCooler setup but its the only picture I have of the hose routing in the driver side fender
http://forums.pelicanparts.com/uploa...1284262383.jpg
JJ 911SC 09-12-2010 10:41 AM
Not sure either... If these are gong to help.
I try to remove the hose from the dryer so I could remove it but its jam. Let me know if you want more photo and where in fefernce to these one.
http://forums.pelicanparts.com/uploa...1284316649.jpg
http://forums.pelicanparts.com/uploa...1284316675.jpg
http://forums.pelicanparts.com/uploa...1284316707.jpg
http://forums.pelicanparts.com/uploa...1284316731.jpg
http://forums.pelicanparts.com/uploa...1284316764.jpg
http://forums.pelicanparts.com/uploa...1284316790.jpg
roger's 2937 09-12-2010 02:12 PM
http://forums.pelicanparts.com/uploa...1284329280.jpg
I just put in new hoses, dryer, etc. in mine and this how it was originally and I also have another 911 and this is the way it is from the factory. Hope this helps.
roger's 2937 09-12-2010 02:17 PM
Here's another pic.http://forums.pelicanparts.com/uploa...1284329812.jpg
llangston1 09-13-2010 05:04 AM
thanks
I believe all the pics that have been posted answered my questions. thanks a bunch.
