Move front 'M' Calipers to the rear?
Guys I have an early car with F & R 'M' calipers on it. The front is getting later BOGE/Bilsteins with Alloy 'S' calipers.
So I am sitting here looking at the removed front 'M' calipers thinking it might be a nice upgrade to mount them in the rear. I know the 'balance' will be off but a proportioning valve could fix that. They will need new lines but everything else is bolt on it looks like. Thoughts? |
I don't think it is worth the aggravation. 48mm pistons vs 38mm pistons is a huge difference to compensate for. I've only seen race cars with pistons that big on the back, and few enough of them. It also adds a lot more unsprung weight.
Is my memory failing or are they different bolt spacing on SWB?
Same F&R on 'M' caliper LWB. Different on 'S' caliper LWB. Best, Grady |
no, a p/v will not correctly compensate you want ~1.6+/- bias, moving front to rear will give you 1 |
You don't want to increase the rear braking on your car. You will find that with the S calipers in the front the brake balance will be great with your original rear calipers. |
They do bolt on as I test mounted them.
OK it seems the consensus is that they are too much unless I go much bigger in the front which I do not intend to do.
I would think that if a four piston caliper was used with larger piston area it would be a nice easy way to add some rear brake without a lot of $$$ investment. By the way the weight difference between the front M and rear M is not very much. |
The Rear M should be a 3" spacing Early Front M had the same spacing. All Alloy S Calipers had a 3.5" spacing so you may have an issue with your struts. |
common choices for the front and resulting hyd bias ratio w/ front M used in back 964 or Boxster 2 993 or 993tt 2.2 930 2 remember you want ~1.6 the bigger rotors used on all of the above further move bias to the front when the car is set up right you can take advantage of more rear bias down into the 1.475 + area, but no further |
Anti-dive (as the 930s had) front suspension might reduce weight transfer.
Anti-dive does not reduce weight transfer, it actually speeds it up. The main way to reduce weight transfer is to lower the center of mass or lengthen the wheelbase.
Don't do it. the results are not an improvement. S fronts and M rears are well set up together. I even run this set on the 911. Think about it. IIRC the pad size is the same and you will need to reduce the pressure to make them work with the fronts. You are now right back where you started. |
You forgot downforce! Big wings go up in angle of attack during high speed braking which adds downforce during the nose down giving further ability to efectivly add rear braking.
Ask me how I know ;) Quote:
Sorry if I confused anybody I have six calipers, two front M, two rear M and two front S. I changed struts and front calipers, swaping in the S calipers in front which left me with two front M calipers I was thinking about putting on the back. I think that I will hold off though now that I am hearing all this.
I do have some 944 Turbo calipers I was once thinking of putting on the front but I am leaning more toward period parts for this car, even if they are not 'original'. I figure the guys in the day were mixing things up that they had access to for race cars so I will do the same ;) Quote:
| All times are GMT -8. The time now is 04:36 AM. |
