88 911 targa
Guest
Posts: n/a
Question Steering wheel play
I have some " play " in my steering wheel/column. By play i mean up and down, side to side movement in the column near the wheel itself. I have read about the bushing replacement in the tech articles section and was wondering if anyone had expirence with this. How difficult was it to do and did it fix the problem? Is this usually the fix, or are there other areas to check out. Thanks for any advice.
Old 07-02-2001, 06:37 AM
motion
Guest
Posts: n/a
Post
Yes, your bushing is gone. Its very easy to replace. Remove the steering wheel and flange, then you'll see the broken pieces of your old busing surrounding the steering shaft. Replace it with a good metal one (try Pelican or Automotion). Don't, I repeat Don't use a plastic bushing. They will break again almost immediately!!!
-Richard
'84 Carrera Cabriolet
'74 911 Widebody 3.6 Project
Old 07-02-2001, 09:06 AM
ChrisL
Guest
Posts: n/a
Post
Replace is a bit of a misnomer. You'll actually push the broken bits of the old plastic bushing down into the steering column as you press in the new metal one. I have a picture of mine that I can email to you if you're interested.
Chris.
Old 07-02-2001, 03:17 PM
88 911 targa
Guest
Posts: n/a
Post
Hey thanks a lot for the info guys, and yes Chris I'd like any pictures of the job that you may have.
Old 07-02-2001, 03:43 PM
davis911s
Guest
Posts: n/a
Post
This is a really easy fix, it took maybe 5 minutes, all you do is take off the whell, push the new sleeve on and replace the steering wheel, and it works GREAT
Old 07-02-2001, 04:59 PM
motion
Guest
Posts: n/a
Post
Pelican has the part:
http://www.pelicanparts.com/catalog/shopcart/911M/POR_911M_miscel_pg4.htm#item17
Looks like they even have step-by-step instructions! And its cheap! Gotta love that.
-Richard
Old 07-02-2001, 05:18 PM
gchappel
Guest
Posts: n/a
Post
I replaced the bushing about 2 months ago- a truely easy job. Thanks Pelican. The plastic bushing was fragmented- which made it very easy to remove.
The hardest part is getting the steering wheel off- an impact wrench makes that really easy.
good luck.
Old 07-03-2001, 07:46 AM
