-   -   SC High idle (http://forums.pelicanparts.com/porsche-911-technical-forum/564390-sc-high-idle.html)
sabeo.m 09-14-2010 05:56 PM
SC High idle
Hi everyone, i did a quick search and couldn't find the answer i was looking for...Hopefully someone can chime in.
I'm getting idle @ 3k rpm's after shutting down the engine (hot) and starting it back up again anywhere after 10-15 minutes. If i wait about a 1/2 hour to 45 minutes, the engine ides where it should. Any thought's? When this happens I have to slowly get into gear and then let out the clutch so that the RPM's drop, but the moment i plant the clutch pedal the RPM's increase again until I can begin normal driving. I was thinking it was the Idle Control Valve/frequency valve, the Auxiliary Air Regulator or EGR Return Valve-not sure which one...
My CIS is in pretty good shape, all new vacume hose's and air box/seal. air
valves and the above mentioned are original. I appreciate any help, TIA.
autobonrun 09-14-2010 08:35 PM
So many possibilities
I recalled a thread on a related discussion (attached); different rpm's but a similar discription. You might also consider buying the K-Jetronic troubleshooting guide. It doesn't cover everything but is not a bad paperback to have in your P-car collection.
http://forums.pelicanparts.com/porsche-911-technical-forum/548527-79-911sc-idle-increasing-engine-temp.html
Amazon.com: Porsche Troubleshooting Guide K-Jetronic: Books
jimrs2000 09-21-2010 08:19 PM
Try pullimg the vacuum hose off of the decel valve and pluging the hose, I use a large self tapping screw.
sabeo.m 09-21-2010 11:50 PM
Thanks for all the replies, I have not had time to look into it yet, but will post my findings.
KNIGHTRACE 09-22-2010 01:24 AM
drop clutch in 1st
