<insert witty title here>
Christien's Avatar
Alt light on at idle - ok to drive?
My alternator will come out for a rebuild in a couple days, because the light's on at idle, and only fading to about 1/4 brightness above 2000 rpm. Am I ok to get away with some driving in the meantime? Will I be charging the battery enough when I'm above 2000 to keep it from draining when I'm idling at a red light, stop sign, etc? Obviously I'll be avoiding traffic jams, and it'll only be for a few days, but I definitely don't want to get stranded.
My experience with my 944 when my VR died was that I was able to drive for about 30-40 minutes on the highway before the car died on me. That was a fun surprise Obviously the 911's not running just on battery, but that experience tells me that the battery holds a lot of juice.
Current: 1987 911 cabrio
Past: 1972 911t 3.0, 1986 911, 1983 944, 1999 Boxster
Old 09-14-2010, 06:49 PM
autobonrun's Avatar
That's a tough question because it's difficult to say just how much charge "dim" represents. We know what the light off and full on means. If you don't have many days until it's being checked, I'd wait.
If I had to drive, I'd use a voltmeter to measure the battery voltage first. Drive but stay close to home. Come back and remeasure the voltage. If it stays the same or increases you should be ok. If it started to drop even a few tenths of a volt, I'd park it. Towing gets expensive.
1979 Porsche 911SC Targa
1996 Porsche 993 C4S
2005 Porsche 996 Turbo S
2020 BMW X3M Competition
2003 BMW M5
Old 09-14-2010, 07:00 PM
Christien's Avatar
When this happened, I was out of town. It was fine driving there, hopped in the car to drive home, fire it up, and 'oh, nice, the light's on'. Drove home an hour and a half (20 min. city, just over an hour highway) and measured the voltage the next morning. I got good #s: off: 12.75, idle: 12.36, load (3k rpm): 14.77.
Old 09-14-2010, 07:05 PM
autobonrun's Avatar
With those numbers, I'd feel ok driving it.
Now you have an excuse for speeding. Tell the cop you have to keep the rpm's over 3k.
2003 BMW M5
Old 09-14-2010, 07:08 PM
no problem at all i had to go without my alternator for an hour of driving my belt loosen and the alternator was not really charging i pulled the belt off. but had no tools to put it back.
1983 911 SC
Old 09-14-2010, 07:20 PM
Christien's Avatar
That's what I thought - thanks for setting my mind at ease.
Old 09-14-2010, 07:23 PM
E Sully's Avatar
With a fully charged battery you can run for a short while, but it could be a problem. Voltage at idle,12.36, shows it is not charging at all. 14.77V at 3000 is a bit high. If you get a voltage spike from a bad regulator you could burn out some electronics or damage the battery.
Pete, running without a belt could easily cause over heating in an air cooled engine. The belt also turns the fan.
Ed
1973.5 T
Old 09-15-2010, 03:27 AM
T77911S's Avatar
basically, the battery is there jsut to start the car. an alt is capable of putting out 90 amps or so, more than enough to power the car. my concern would be that the alt completely dies while driving, and yes you can drive for quite a while on just the battery, shorter if you have to use lights. lights are a big power drain, keep your foot of the brake while stopped will help if the alt dies and you have to run on battery.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 09-15-2010, 03:45 AM
But i was heading off to a highway with only two traffic light stops on a cold engine.
No over heating occurred.
1983 911 SC
Old 09-15-2010, 04:07 AM
gtc gtc is offline
abides.
gtc's Avatar
No offense but....
This is about the worst thing you could have done.... driving the car without the fan spinning is pretty effing stupid.
Graham
1984 Carrera Targa
Old 09-15-2010, 08:27 AM
Do a search.. I don't have all the electrical details in front of me but the car should never be run with the alternator disconnected or not functioning.
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 09-15-2010, 10:17 AM
