Solid Core Wires?
Can anyone tell me if these are solid core wires?
http://forums.pelicanparts.com/uploa...1284831067.jpg http://forums.pelicanparts.com/uploa...1284831092.jpg Thanks! |
I can't say for sure by the photo but a quick check with an ohm meter will. If the resistance measures "0" they're solid core. Resistor wires are around 8,000 ohms per foot. Rob
Looks like solid core. |
So does anyone know what would happen if I used these wires with an MSD ignition and MSD coil?
Info is under 'installation section'. |
Solid core wires use resistor ends for suppression and will short out with the higher energy ignition. Carbon core wires are made for high engery ignition systems.
With carbon core ignition cables HEI rated and plugs gapped at 0.060". http://forums.pelicanparts.com/uploa...1121574427.jpg Stranded copper wires could never perform in these conditions. Cheers, Joe |
Resistor wires are recommended for late model vehicles to reduce EMI affecting the electronics. Sherwood |
I would also disagree with the gap of .060.
Steve W and others recommend a gap of .045 to .050. Quote:
| All times are GMT -8. The time now is 10:55 PM. |
