-   -   Alternator interchange question??? (http://forums.pelicanparts.com/porsche-911-technical-forum/565152-alternator-interchange-question.html)
pistolpete 09-18-2010 04:11 PM
I have a 1973 911e that has a bad alternator! I found an alternator that fits a 1984-1989. Will this interchange?? I understand I will have to do some rewiring and this one has an internal regulator.
thanks for your help!!
86 911 Targa 09-18-2010 04:31 PM
Our '86 does have an internal VR.
But, over and above that, you may have a pulley/size/alignment, and mounting/ issue(s).
Just have yours re-built by a competent shop, or do an exchange by a competent source.
By the way, there is a distinction between re-furbish, and re-build.
Good luck,
Gerry
DUK 09-18-2010 05:43 PM
I believe one thing you'll find is the depth of the alternators is different. So the fan belt spacing will be wrong.
Do what Gerry said.
