-   -   Another where can I find (http://forums.pelicanparts.com/porsche-911-technical-forum/565257-another-where-can-i-find.html)
magnuskgc 09-19-2010 10:29 AM
I need to get a diagram for the fuse box in my 85 SC... I used the search function but only seem to find one from earlier models... are they the same?
Or if anybody has a resource for this I appreciate it
nesslar 09-19-2010 10:48 AM
'85 SCs are fairly rare; might be tough to get ANY info on one....
Just kidding, but someone should be able to email a copy of what you need. I should think someone would PM you with a request for your email address so they can send you one............I presume you mean "Carrera" ... :)
86 911 Targa 09-19-2010 11:08 AM
No sure what you mean by "diagram".
Are you looking for fuse assignment(s)?
Or, the actual wiring?
The our Bentley has both for the 84-49 model years.
Never heard of an 85SC....
Good luck,
Gerry
crustychief 09-19-2010 11:20 AM
85 sc? 49 911?
http://www.pelicanparts.com/911/911_Parts/911_electrical_diagrams.htm
magnuskgc 09-19-2010 03:22 PM
My bad.. its and 85 Targa.... I need more coffee today. I need the fuse assignments....
I am also trying to figure out some wire locations but that is another story.. I bought the car with allot oe things missing off of it and not I am chasing things around.
most note worthy is I upgraded to the newer headlight and not the passenger side is much more dim then the driver... I believe it is a ground problem. Except now I found out I am loosing 12v to the parking light when the light is on and pops a fuse.
86 911 Targa 09-19-2010 05:20 PM
Here are the fuse assigments for your '85.
They are also listed on the inside of your fuse/relay cover.
Good luck,
Gerry
http://forums.pelicanparts.com/uploa...1284941992.jpg
tcar 09-19-2010 07:33 PM
My bad.. its and 85 Targa.... I need more coffee today. I need the fuse assignments.... .
Look at the inside of the fuse cover.
magnuskgc 09-19-2010 11:07 PM
I do not have a fuse cover at the moment.......Thanks for the info guys.
