Alternator question: Paris Rhone and Bosch interchangeable?
It's time to replace the alternator in my '88 911. It's a Paris Rhone unit (PN: 911 603 120 05). http://forums.pelicanparts.com/uploa...1285080756.jpg My local Porsche parts guru says "Rebuilt Paris Rhone units are crap." He says get a new one or a rebuilt Bosch unit. Hmm. Pelican Parts has a rebuilt Paris Rhone unit for $189. I called them to ask ... no complaints they know of ... so does anyone here have experience with a rebuilt Paris Rhone alternator? If it's not up to par, does anyone know if a Bosch unit is directly interchangeable with the Paris Rhone, i.e., are the connections exactly the same? I'm getting conflicting answers. Some say I have to rewire the back ... something to do with the idiot light. Thanks in advance for your answers. |
Yes, the connections are identical. There are only B+, D- and D+/61 on the back, these are internally regulated alternators that do not use a DF wire or external reg.
Be extremely careful, disconnect the battery negative before working on the alternator, if the B+ shorts to ground you will have an 800 amp arc welder back there, could cause personal injury or property damage. |
LOL, my Paris Rhone Alt needs rebuilding about every 40k miles. What i've done is bought a second unit so there's no down-time, i just swap them out.
Thanks for the info 304065. One thing: I think you meant to disconnect the battery's positive in this particular case, right?
Targa Me: so you are saying that they are crap, then? What is wearing out on them -- the bearings?
It's a crapshoot. I bought a rebuilt Bosch, and it went bad within a week. I believe my mechanic got me another Valeo, and all has been well since then.
According to my records, my car's alternators last about 75,000 miles. I guess I'm due for another one next year. |
Man, I just don't get it. If the brushes, bearings and voltage regulator are replaced, why can't these reman units go the distance like the OE units? (180,000 miles in my case).
BP, it always seems like its the bearings that are failing.
If you disconnect the positive you still have to worry about accidentally shorting to the positive terminal. If you drop a wrench on the positive and it hits the body, spark time. If you disconnect the negative and drop a wrench on the positive and it hits the body, nothing happens. |
Got ya 304065 ... thanks ... well I pulled both terminals off yesterday for good measure. Plus when it comes to ignition parts, I have no idea what wires may still be hot, and only need to find a ground and ZAAAP.
FYI, I have found a place here in Oceanside Calif, who does a total rebuild of the existing unit for $165, including high quality bearings, etc. ... not the type that last for only 40K miles. Richer Auto & Truck Electric -- (760) 757-1201 It'll be done in two days. If it's less than expected, I'll let you know, otherwise I'm a happy camper. |
| All times are GMT -8. The time now is 03:45 AM. |
