RETIRED
So when the power went out last week.....I was looking in the garage for the lanterns and other emergency crap......
I needed light, so I turned the ignition on, cranked up the H4s, and hood mounted Cibies helped me out. Found what I needed and turned off the key..... Fast forward a week.....FUCH!!!!!!! I left the dash switch on, KILLED the yellow top deep cycle OPTIMA.......5 years old+ My Handy Dandy Sears analog charger, went full tilt.....then zap.....zero.....full tilt....zap zero......first time it ever failed me. The Sears digital one....which I HATE BTW, has a 100 amp qwik start option......tossed it on the terminals along with the Fluke....POS read 7.25 volts. Had a fatty, a cocktail, decided to proposition the GF, or vice versa......went into the room and put the dog in the crate.... Came back out afterwards.....not gonna tell ya how long..... The fluke was climbing.....8.23 volts......3 hours later, over 12.5. Pulled the leads, fired the 3.6 up.....woohoo. Gonna leave it at 2amps over night......hopefully it hold a charge...... LONG LIVE OPTIMA YELLOW TOPS!!!!!!!!!!!!!!!!
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430 I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!! How about a NoBadDays DualChip for 964 or '95 993 |
19 years and 17k posts...
I used a C-Tech charger with my Optima red top. The C-Tech charger is the right gear to use for those batteries!
Art Zasadny 1974 Porsche 911 Targa "Helga" (Sold, back home in Germany) Learning the bass guitar Driving Ford company cars now... www.ford.com |
Why did you go with Yellow Top?...no real advantage over Red Top and typ used for deep-discharge cycles....it's not a "Red-top-plus" better model....just made for different duty .
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
RETIRED
Deep cycle and I run a lot of accessories. It's over 5 years old and has done well....
And Ingo.....the whole charge process took 4 hours at 100amps......it was DEAD.
4 hours at 100 amps???
Don't try this at home folks. Only a guy named Joe Bob can do this.
RETIRED
Sorry, alternated between 100 and 15 amps. I wouldn't take a charge at anything less. It's now taking a 2 amp charge.....
PRO Motorsports
Just brought back a totally dead Odyssey PC925 this way too.
Had to whack it with the 80 amp quick charge setting for an hour before it would even register on the meter, then switched over to 40 amp charge. The needle slowly climbed from almost zero amps to 5, then ten, then 15. Totally backwards to what is normal. It's discouraging when you you hook up a dead battery to the charger, and the needle doesn't budge, but you just have to be patient. But the AGM batteries need to be hit with a lot of amperage before they will come back.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer) '72 911T Targa MFI 2.4E spec(Formerly "Scruffy") 2004 GT3 |
RETIRED
Yep, I remember reading that was the cure for deep dead deep cycle batteries.....it worked. The battery at rest shows 12.85v which pretty close to where it's been for the life of the battery. I'm just amazed at how much abuse this unit has taken.....
A load test at 2500 rpms with all the lights, blower motor, radio with power amps showed 13.66v......
Platinum Member
A load test (capacity test) of the battery would be to turn the lights on with the engine off, and measure the voltage & current over time. (to get amp-hours of stored charge) |
RETIRED
Yeah, you're right wrong use of the term "load test".....anywhoo, it's running and starting, Mission Complete.
This is what Optima recommends.
1976 911S Targa, Carrera bodywork, 3.2l engine. Last edited by Roc Doc; 09-26-2010 at 09:24 AM.. |
I bet you your GF will be sneaking into the garage now from time to time to turn and leave on the high-beams. 4h isn't kidding around
