-   -   Question on power mirrior switch-Yes I am a newbie... (http://forums.pelicanparts.com/porsche-911-technical-forum/566146-question-power-mirrior-switch-yes-i-am-newbie.html)
84TurboLook 09-24-2010 06:42 AM
Hello All,
Newbie here; new to the forum. Not so new to cars...
Just bought an '84 Turbo Look car. Car has sunroof and at least one power mirror. I say one because I cannot find the little rocker switch that is supposed to toggle from left to right. The switch for the sunroof seems to occupy the spot where the mirror selector switch usually is.
What gives? Do I only have a power mirror on the left side? I'm almost embarrassed to ask, but I can't find any damn switch to control the right mirror!
Here is the car...
http://forums.pelicanparts.com/uploa...1285335621.jpg
Thanks,
Mike
Bob Kontak 09-24-2010 07:27 AM
Mike,
Nice looking car.
The mirror selector on my 81SC is right below the temp/oil pressure gauge on the surface parallel to the ground. Not easy to see. Is this where your sun roof switch is?
NewfieMZ3 09-24-2010 08:21 AM
same spot on my "84.........switch rocks from the left to the right, horizontal, a little hard to spot down there.
Targa Me 09-24-2010 08:51 AM
Welcome Mike, beautiful car.
+2 on the switch location.
84TurboLook 09-24-2010 09:22 AM
Originally Posted by Bob Kontak (Post 5578848)
Mike,
Nice looking car.
Yes that is right where my sunroof switch is; but alas, no mirror switch! I checked and I can feel a indentation where the switch should be I think. Is it possible to have just the LH power mirror and not the right one? Kinda strange, or I'm just not smart enough:confused:
Thanks!
Mike
86 911 Targa 09-24-2010 10:47 AM
Thanks!
Mike
Mike,
Here are two jpegs from our '86 owner's manual.
The switches appear to be as per previous posts.
The right mirror was an option (261), or (262)
on the 1984 model.
The mirror options were:
#261-Electrically adjustable and heated.
#262-Manual and not heated. (no switch).
Google "1984 Porsche options+right side mirror".
Good luck,
Gerry
http://forums.pelicanparts.com/uploa...1285350378.jpg
http://forums.pelicanparts.com/uploa...1285350394.jpg
79 Euro 09-24-2010 12:19 PM
I have a 79 SC w/ two mirrors. Driver side is powered, passenger side is not!
Sounds backwards doesn't it. I can roll down the driver side window but I can't reach the passenger side to adjust.
jmitro 11-15-2010 11:58 AM
does anyone have photos or instructions about the power mirror switch wiring? the knob is on top of the door panel, with 6 wires plugged into the switch. there is no numbering on the switch, so i have no idea where the wires go. i burned the fuse last night trying to figure the wiring out.
FIG 02-24-2011 01:18 AM
Ok.... I must be daft....?
RHD (Aussie car) '78 911SC
My right mirror (elec & heated) works fine from my door switch for the mirrors
My Left mirror (also elec & heated) doesn't work coz I have NO selector switch next to my sunroof switch? WTF?
PS, I know my left mirror (passenger) is elec & heated as I removed it and found all the wiring. I also plugged it into the drivers side mirror plug to check it works and sure enough it did!
Any suggestions?
JJ 911SC 02-24-2011 02:21 AM
[QUOTE=86 911 Targa;5579242]
... The right mirror was an option (261), or (262)
on the 1984 model.
Google "1984 Porsche options+right side mirror"...
QUOTE]
Mike
Run you VIN here and see ywhich option you have; Porsche VIN Decoder, VIN Lookup, Decode VIN
