UNDER CONSTRUCTION!
help identify these 15x7 fuch wheels 6/73
Hey guys
i bought a parts car and these wheels where on the rear, when i first looked at the wheels they where wider than normal and assumed they where fake. but they have 911 numbers any help would be great thanks guys. i know someone on here has a book with the numbers listing ![]() cheers ed ![]() ![]()
Sometimes the first thing that comes to mind should be the last thing that you do!
911 Wheel Weights
Wheels fitments, all are 17" unless other wise specified Fuch Size & Offset chart? Need to figure out the last digit. An .05 would be a 15 x 11 and you don't have that! |
UNDER CONSTRUCTION!
milt the last digit is an .01
cheers ed i will check the other wheel for its number, they are 3 prong wheels so the 73 date code seems right. i have read about these wheels being imported in to sell in the 70s but hevent run across any. i just cant find any information that states anything about them. cheers ed
PET shows it to be a 15 x 6j.
911.361.020.11 would be the 15 x 7j. Sure looks like a 7 or 8 on the face. It also looks like a 16 in ways. |
UNDER CONSTRUCTION!
it is for sure a j7x15
and the last two digits are for sure 01 on that wheel. but will check the other ed
UNDER CONSTRUCTION!
ok i double checked the other wheel it is an 01 wheel as well and dated 6/73 soo at least they match. i have read about miss marked wheels maybe they both got marked wrong? i mean if they dont exist on paper maybe they are stamped wrong.
cheers ed
UNDER CONSTRUCTION!
Fuch wheel ID
I do not know my wheel ID codes but they look really cool. Great Find!!
You only live once so you better have fun FAST!!! |
Looks like you figured this out already. To confirm this for you Ed you have a pair of early flat 7" wheels that would have come on the '73 RS and the Carrera 2.7 in '74-75. These are fairly hard to find so they certainly carry a premium.
The early flat 6" wheels have a .00 ending and the 7" has .01 with the smaller inner hole for a three prong cap.
Brian '73 Carrera RS '71 911S coupe 'Patrick' '16 Cayman GT4 '91 C4 coupe |
UNDER CONSTRUCTION!
does anyone know of any actual data that proves what these wheels are ? thanks for everyones help so far. cheers ed
Hi Ed,
Obviously you will never the exact history of these particular wheels. You said you bought a 'parts car', what year and model is this car? We know these were made in May, 1973 so they may have been put on a late production '73 RS or sold as a pair to someone wanting 7" wheels on their '73T, E, or S. The other possibility was they put on a '74 Carrera or sold to someone later on to put on their '74 911. The finish is most likely orignal which would have been correct for a '73 or '74 911. In '75 they went to all black center. If you want to talk with the ultimate Fuchs guru contact Harvey Weidman. He has been around these wheels since the early '70s and is the premier refinisher of these wheels. Send him a link to this thread at weidmanwheel@sbcglobal.net or call (530) 534-7903.
gearhead
I'm pretty sure that a wheel made in June of '73 would have never been installed on a '73 RS. That's just to late. That's right before they start making the '74 models IIRC.
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
![]() I have this pair date stamped 6/72........... ![]() ![]() I assumed they were for a 73RS but is there any way to confirm this? They are 7Jx15 and have PN 911 361 020 01. Len at Autosportengineering dot com
UNDER CONSTRUCTION!
Hey guys i thought i read some where that the first number in the date was the week they where made I.E. 6/73 would be 6th week of 73 making these early 73 ?
cheers ed
gearhead
Different manufacturers/subcontractors do things differently. I think in your 901 thread we were talking about gearbox pro-dates, which are the week. AFAIK, Fuchs wheels are months.
UNDER CONSTRUCTION!
thanks for clearing that up you are right on the 901 thread thats where i remembered it from. i have picked up a 71 901 for my 69 912 4spd car will post its numbers on the other thread to see if its final drive is any deeper, thanks for all your help. cheers ed
Bandwidth AbUser
Probably not easy to confirm. The Porsche parts list (1973) shows a p/n 911 361 20 11 7Jx15 wheel, and no p/n 911 361 20 01 at all. On the other hand, I wonder how Porsche treated p/n's for the 7Jx15 Fuchs that had a variety of different paint finishes. Who knows?
Jim R. |
Bandwidth AbUser
Jim R. |
UNDER CONSTRUCTION!
thanks for the number for harvey hes a great guy to talk with and says they are an accessory wheel sold by porsche and brought in by the 100s. they are going to be shipped down to him and he will determine the condition and then i will make a decision on what to do with them. maybe find them the correct car to fit under. thanks ed
Yeah, Harvey is the best at these wheels. I'm not surprised he thinks they were sold as an accessory part.
Brian '73 Carrera RS '71 911S coupe 'Patrick' '16 Cayman GT4 '91 C4 coupe Last edited by fryardds; 08-25-2010 at 01:49 PM.. |
