Major bang for the buck--shifter rebuild
I just completed a rebuild of the shifter mechanism in my 70 911 (901 trany).
What a difference!!!!!!!!!!!!!!! Of all of the maintenance I've done on this car, this process provided the most improvement of driveability for the least amount of money and time.
The rear bushings finally gave out last week so shifting became a challange. It forced me to do the repair.
Like the frog in the pot parable, the degredation in the shifting was so gradual that I really didn't notice until the rear bushings broke up.
Anyone with more than a couple of inches of play in their shifter should consider this cheap and easy process. The parts are cheap ($20-30) and the process is not real difficult.
On inspection, the shift plate was worn so I changed it out as well. That was the toughest part 'cus of the springs. If you do the shift plate, I can help with the process. I remembered a posting by another Porsche guy about this, but I can't remember his name. It was extremely helpful.
If you have any doubts, go for it. OK, I've rambled enough. Going back to my Corona now.
Rob
Rob
356robo
70 T Targa
Looking for a 2.2,2.4, or 89 coupe
Old 09-22-2010, 06:40 PM
did the same with huge improvement and haven't even fine tuned coupler settings yet.
Old 09-22-2010, 06:51 PM
Bye, Bye.
Scooter's Avatar
+2
Rebuild the shifter and coupler along with the replacement of the shift rod bushing makes a world of difference.
Elvis has left the building.
Old 09-22-2010, 06:56 PM
Science is NOT optional
rbogh901's Avatar
a couple inches of play when? in gear?
PCA member since 1993
Old 09-23-2010, 08:59 PM
The manual says that free play in all gear positions should be similar side to side and front to rear. After replacing all 4 bushings, 2 in front and 2 in the shift coupler, my free play is about 1 - 1.5 inches in all directions.
Rob
356robo
70 T Targa
Old 09-24-2010, 01:46 PM
Rob
Have you tried a downshift from 5th to 2nd at 1.25"
BTW, "free play" usually means the distance a part moves before anything significant happens. For a shift housing assembly, 1-1.5" is either excessive or needs redefining.
Sherwood
Old 09-24-2010, 02:12 PM
Detached Member
Hugh R's Avatar
Did mine when I bought it 7 years ago. Major improvement, did it in a morning, not knowing what I was doing, other than Wayne's book.
Hugh
Old 09-24-2010, 02:16 PM
19 years and 17k posts...
azasadny's Avatar
Did mine a few years ago and it made a huge difference!
Art Zasadny
Learning the bass guitar
www.ford.com
Old 09-24-2010, 03:43 PM
