Speedometer
Ok,
Newbie here again, ok, so the speedometer tells me how fast I am going, but the mileage counter is not working. Anything I can try, or look for? Suggestions? Thanks! Rod |
There are numerous posts on this subject. Search "Odometer Gear". I had mine done at Paul's Speedometer shop in Redondo Beach. Where are you located? Gerry |
Broken odo gear,..
NHW Repair rework (for safety),..or fix your self (can be trying)..................... happy readings!...Lotsa' good threads w/ pics out there. |
From posts you will see that the odometer gear breaks. Mine broke when resetting the trip odometer. I believe the rule is don't reset it while the car is moving. See if your trip odo says zero miles - like mine did.
| All times are GMT -8. The time now is 04:44 AM. |
