New to me 911 SC
I purchased the below 911 SC from BAT a few months ago and am looking for any information or history on the car that members may have. So far it’s been a well sorted example and I have so far put about 800 miles on it here in the CO canyons.
Recently did a full fluid flush and valve adjustment, which only 2 needed some adjustment… VIN: WP0AA091XCS122404 https://bringatrailer.com/listing/1982-porsche-911sc-153/ ![]()
Coram Deo
Lovely car. Can't tell you anything about the history, though. What did the seller tell you?
Dru 1980 911SC Targa • Petrol Blue Metallic • Cork special leather • Sport Seats • Limited Slip • 964 Cams • SSIs • Rennshifter • 1990 250D Opawagen • 1995 E220T Sportline Familienwagen • 1971 280SE Beverly... hills that is • 1971 Berlina 1750 Faggio • |
Great looking car.
72 911 Although it is done at the moment, it will never be finished. |
Nice !
I noticed the prior owner paid $160K for it last October.
John D. 82 911 SC Targa-Rosewood 2012 Golf TDI |
Maybe install screening to protect your center oil cooler. Nice looking ride.
If you give your word: keep it. |
Thanks all, it was through BAT sold by a consigner so no real history other then some records on the engine build.
There is mesh in front of the cooler, you just can’t see it. (It catches lots of bugs) Paid $145k delivered, no bat fee which was a plus. |
Reach out to the original BaT dealer — 911r aka Avant Garde in Portland, OR — and see if they’re willing to connect you to the prior owner?
Looks like it otherwise bounced between speculators a bit at the peak of the market. 3.8L stroker build == sounds like it’s a fun car!
1978 911 SC (3.2SS, EFI, 993SS cams + the trimmings) Dynamic Comp Ratio calc: https://dcr.questionable.services/ • Gearset & Ratio calc: https://ratio.questionable.services/ |
No response from avant guard but I did put a ducktail and new wheels on her!
I like the new look a lot more. ![]()
That looks great.
Ravi 1974 914 2.0 1975 911s 3.0 2014 Cayenne GTS 2016 Cayman GTS |
Curious about the Group 4 wheels you pulled off. Do you know size (ET?)Can you confirm you have 930 flares? Looks like it in the rear. Can’t tell for sure up front.
Sorry I don’t know the offsets but I have the RSR flares front and rear ![]() Sent from my iPhone using Tapatalk |
Coram Deo
Wheels are definitely three steps up.
Perhaps I’m in the minority. Although I prefer no tail, I’d take a duck over a whale and I’d rather Fuchs over most wheels. All that said, the smaller diameter Campy, fat sidewall and whale worked very well on that car to my eye. To each his own and you’ve done well to make it your own as you should.
Grease Monkee
Love the visual changes you made. Was wondering where this car was going to end up as it seems to have changed hands a few times. Looks like a great build!
86 911 Carrera Coupe 99 996 C2 Coupe (former) |
Thanks all! I’m chipping away at making it mine little by little and performing routine maintenance. - I have had some amazing drives with it so far and it doesn’t sit much.
I want to focus more on drivability next. So planning to add either an electronic exhaust valve or 100 cell cat to make it loud/quiet. Waiting to add classic9 electric heat and AC when that comes out. Eventually I want to reupholster the interior and freshen that up a bit but that’s more of a winter project. Car really rips though! |
