-   -   Alt light flashes, idle speed increases (http://forums.pelicanparts.com/porsche-911-technical-forum/566409-alt-light-flashes-idle-speed-increases.html)
lazerander 09-25-2010 06:10 PM
While idling, my 1968 911L will suddenly flash the altenator light on for half a second and then immediately the idle speed increases 200-300 RPM for a few minutes and then settles back down to the previous RPM. What could possibly cause this?
john walker's workshop 09-25-2010 06:17 PM
when the alternator is charging, it creates a small load on the engine. it's not charging when the light is on, so the engine doesn't have that load and speeds up a bit. check your brushes.
lazerander 09-26-2010 07:03 AM
Thanks for your input, John; what you say makes sense. What I'm confused about is,
why does the higher RPM persist for several minutes, after the "not charging" light had
only flashed on for a split second?
I'm going to pull out the alternator, follow your advice and check the brushes. I'll send
you some feedback on the problem as I progress, hopefully to its resolution!
