Bbs socket
Can anyone tell me what or better yet sell me the special(I assume) socket for disassembly of BBS 3 piece wheels? Thanks Frank
Based on a few searches of Google, I see that the tool you probably need is an 8mm triple square bit.
I have bought a couple for my Beetle and Passat suspension work. The best quality I have seen is a KD bit through NAPA. You can buy them individually - $10 range. Call your local NAPA store and they will have it in a day if not in stock. Sears also sells them. The term triple square probably refers to the twelve points in the pattern. http://www.sears.com/shc/s/p_10153_12605_SPM240840347P |
8mm or 5/16" 12 point socket.
| All times are GMT -8. The time now is 09:44 PM. |
