Yep, I've done that!
joeblow's Avatar
74'+ oil tank into a 71'?
Guys,
I have a 71' with original tank and have been resistant to changing it despite having a 2.7 ltr Webered engine with large front mount cooler set-up etc... I have the 26mm to 30mm adapter and jerry rigged 'S' hose too.
Now I was putting in my 'S' gauges and went to install my new oil level sender and guess what, no hole to install it into. I could drill a hole and such but I think the time has come to get another tank.
So my question is, will any 74'+ tank just drop in? Is the filler/oil filter and such in the same place or am I looking at fabrication work. I assume my 'S' hose will just slip on and the 26mm/30mm adapter will be ditched?
Also is this a good opportunity to put in the RSR adjustable pressure regulator set-up?
Thanks!!
71' 911 Fully restored Tarmac Rally Long Hood RSR
03' Audi Allroad 2.7ltr Twin Turbo 350 HP Ski Machine!
00' Aprilia RSVR Mille SuperBike highly modified...Yep fun fast!
86' 944 SPEC Car 'In Process' 2013 Debut
Old 09-27-2010, 08:19 AM
PRO Motorsports
Tyson Schmidt's Avatar
No, the opening in the inner fender well is different.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer)
'72 911T Targa MFI 2.4E spec(Formerly "Scruffy")
2004 GT3
Old 09-27-2010, 04:33 PM
Platinum Member
dad911's Avatar
I did it. Cut out the inner fender well to fit. It solved an oil starvation issue at the track in the corners.
Old 09-27-2010, 04:48 PM
Under the radar
Trackrash's Avatar
It's a worthwhile upgrade. You will have to do some sheet metal work in the engine compartment though.
A newer style front cooler will bolt right up as will the "s" hose.
Gordon
'71 911 Coupe 3,0L outlawed
Old 09-27-2010, 05:29 PM
joeblow's Avatar
What material are the tanks? Brass? I suppose I could just modify the return fitting from 26mm to 30mm and cut the hole for the sending unit. Thats the only real difference right? I mean there is no other secrets to the 74+ tanks right?
Old 09-27-2010, 07:17 PM
PRO Motorsports
Copper plated steel, IIRC.
2004 GT3
Old 09-27-2010, 07:30 PM
joeblow's Avatar
So it should not be too difficult rob a 30mm male fitting off an old pipe or tank and TIG it on there?
If I have to start cutting stuff I would rather it not be my car but a removable part like the tank. Cutting a hole to mount the sender is not a biggie.
Thoughts?
Old 09-27-2010, 07:47 PM
Under the radar
Trackrash's Avatar
The advantages to the newer tank are:
More capacity.
The return fitting has been relocated so you won't starve the motor of oil during braking and cornering.
The internal passages are larger for more flow to better suit the newer motors.
You then use the newer oil filter which has more capacity.
When Porsche went to the 2.4 and larger motors there was a reason why they increased the oil capacity of the tank and oil lines.
Gordon
Old 09-27-2010, 08:08 PM
joeblow's Avatar
Can sombody detail what needs to be done to modify the inner fender? Is it substancial?
More capacity.
Old 09-27-2010, 08:10 PM
Under the radar
Trackrash's Avatar
Here's a pic. You can see where the old hole was since I didn't bother to spend a lot of time to pretty it up where I welded in the patch.
Gordon
Old 09-27-2010, 08:19 PM
joeblow's Avatar
What about going the other way? RS/RSR/ST R?
What did they do?
Old 09-27-2010, 09:19 PM
