Plastic Roll Pins? Found in center tunnel…
Just need help ID’ing these plastic pins.
Found them in the center tunnel while doing tunnel fuel lines. Tried the PET, ChatGPT and Google image search so far and can’t seem to figure it out. Thanks! Allen socket for comparison.
Is your car silver?
PCA Member since 1988
What year car?
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
Those are what the factory typically puts over threaded studs to keep primer, paint and schutz from fouling the threads.
