NeunElf3.2's Avatar
Help- washer switch / electrical
Help- After replacing the turn signal switch, I have no power to the car (no bulb check,etc.) When I pull the washer stalk for "wash", all power is available.
I've tried unplugging/reinstalling the bulkhead and ignition conenctors; sprayed contact cleaner on the wipr sitch contacts.
What did I screw up???
Old 06-11-2010, 12:09 PM
NeunElf3.2's Avatar
Addendum- The "wash" function on the stalk will power up the car without the key in the ignition.
Old 06-11-2010, 12:33 PM
pete3799's Avatar
What car is this on.
Pete
79 911SC RoW
Old 06-11-2010, 01:00 PM
NeunElf3.2's Avatar
what car
88 Carrera coupe
Old 06-11-2010, 01:07 PM
pete3799's Avatar
What was the reason for the new turn signal switch?
Pete
79 911SC RoW
Old 06-11-2010, 01:10 PM
NeunElf3.2's Avatar
no "flash to pass" feature
Old 06-11-2010, 02:12 PM
pete3799's Avatar
So everything was working normaly before you plugged in the new switch?
Did you mess with any wiring before replacing the switch?
Sorry for all the ?'s but i can't see how a new turn signal switch would cause this.
Did you switch the plugs on the bulkhead by any chance.
Pete
79 911SC RoW
Old 06-11-2010, 02:29 PM
NeunElf3.2's Avatar
Bulkead plugs are in correct position. I just removed the connector from the ignition switch and the bulkhead; "wasH' still gives power to car- moving wiper switch up engages starter!
Is there any way that an incorrect disconnect to the light (dash) switch could cause this?
Old 06-11-2010, 02:42 PM
NeunElf3.2's Avatar
Dumb*ss alert !
Yep. I was sure that the bulkhead connectors were installed right- I didn't think that the wiper/light connector fit in the ignition spot- WRONG!
Switched the wiper and ignition connectors and voila!
Thanks for the help.
Old 06-11-2010, 02:47 PM
pete3799's Avatar
No problem.
Glad I could help.
Before you throw out the old switch do a search on it.
You probably can fix your old one and have it for a spare.
Pete
79 911SC RoW
Old 06-11-2010, 05:44 PM
pete3799's Avatar
Forgot to mention you should put a headlight relay on (if you haven't already) to prevent your new switch from failing.
Search "headlight relay"
Pete
79 911SC RoW
Old 06-11-2010, 07:05 PM
NeunElf3.2's Avatar
Already purchased relay; trying to change things sequentially so that I know when I make a mistake
Old 06-11-2010, 08:41 PM
That would be a great security feature- use the washer stalk to start the car and the key to fire up the washer....
Old 09-30-2010, 09:01 AM
