Electrical - Relay question ???
On a '72 911T does the "blinker relay" also control the brake lights and the backup lights? Or does it only work with the blinkers? Flashers?
I looked at the wiring diagram for this car (both online with our host and in the shop manual) and I can't find the relay in there anywhere. Sorry, I'm a decent weekend mechanic but electrical work confuses me. Thanks much! |
It does not control the brake or back up lights. Back up lights are controlled by switch on transmission and brake lights from switch on master cylinder.
Ed 1973.5 T |
Thank you!
The blinker relay control all that lights that blink when activated. this includes the turn signals, hand brake/bake failure lamp and emergency flasher.
To help follow the early wiring diagrams, I find is useful to enlarge them and use a highlighter to trace the wires I am trying to verify.
