-   -   cannot turn the ignition key (http://forums.pelicanparts.com/porsche-911-technical-forum/567280-cannot-turn-ignition-key.html)
remigio 10-01-2010 12:18 AM
good morning. i am a fairly new firsttime owner. so far, i have had no major issues with the car. i bought this 86 targa in july and so far so good. even took it on a road trip, no big problems to speak of. however, on a couple of occasions, the ignition key barrel would not turn, the last time being last night. on both occasions we solved it by jiggling the steering wheel.
obviously, the questions here then are, (1) is there a mechnical interlock between the ignition and the steering column and (2) if there is, is the interlock in my car going bad, or already bad?
i've had a few cars since i was eighteen and i've never had ANY ignition barrel freeze unless the wheels are at "the stops" hard left or hard right.
comments. advice?
thanks
remigio
aigel 10-01-2010 12:40 AM
The ignition lock also locks the steering column. Did you try to rotate the steering wheel either direction while trying to turn the key. Often the tires preload the steering to push in one direction, not allowing the ignition lock to unlock the steering column. What I am saying is that you should wiggle the wheel left and right while turning the key.
If that does not help, you will have to dig deeper into the mechanics of ignition lock and steering column.
Hope this helps.
George
twistoffat 10-01-2010 01:30 AM
The Key could be worn. Have you tried another key?
JJ 911SC 10-01-2010 02:08 AM
Did you ever had problem with the same key, locking/unlocking the doors?
How old is the car?
pete3799 10-01-2010 05:18 AM
The first thing i'd do is clean the tumblers. Spray some brake clean in the key slot (hold a rag under it to catch the drips) spray,insert key ,spray insert key until the fluid comes out clean. Then use Lock Ease or similar graphite lube. If you have a spare key try useing it.
I had the same problem and this plus using the spare key has solved it so far.
kach22i 10-01-2010 05:44 AM
I keep a can of PB Blaster or WD40 in the trunk (must have straw) for when this happens.
My suggestion is to put a large rag or towel on your lap/legs and wear shorts. That way the drips can be wiped up and you will not ruin yet another pair of pants.
I also leave the old towel on the floor to catch any drips over night.
It's a messy deal but replacing the assembly and re-keying the tumbler seems like another expensive time consuming project.
I like pete3799's suggestion but that graphite stuff seems to stay on my keys and get all over my clothes, even weeks after application. I'm going to try carb/choke cleaner and follow thru with PB Blaster next time I do this. I do this once or twice a year to keep the key demon at bay.
HarryD 10-01-2010 06:47 AM
My locks were balky when I got my car in 2002.
I used WD-40 to clean the gunk out followed by a shot of TriFlow Lube (as recomended by by Locksmith).
Voila! Smooth, easy operation.
Now, every 6 months I put a shot of TriFlow in the locks and I have had zero problems since.
WIL84911 10-01-2010 07:13 AM
Originally Posted by aigel (Post 5590748)
...try to rotate the steering wheel either direction while trying to turn the key.
+1. Happened to me the other day.. almost broke the key... I guess it comes with age (speaking for myself)..
mschwien 10-01-2010 07:49 AM
Mine was not easily returning back from the start position - WD-40 with rag underneath to catch the drippings - no further problems and that was over 2 years ago
kach22i 10-01-2010 07:54 AM
You are about due for more problems then. Nip it in the bud and lube it up again just to be safe.
313green 10-01-2010 08:48 AM
same problem with my 72 911
when you remove the key, you will notice a small click (you'll hear it too).
i've found that if i remove the key too fast, the click doesn't happen.
the click is some sort of ignition mechanism.
once you get the key out, make sure you always remove it slowly (turn it all the way to the left so it's perfectly straight, then remove).
aigel 10-01-2010 10:33 AM
I would not lubricate key / tumblers with oils. Graphite only. Oils will attract gunk off the key and will gum up your lock in the long run. Graphite doesn't do this.
George
RWebb 10-01-2010 12:04 PM
yup. that's what I've always heard
but all the locksmiths around here seem to use TriFlow (Teflon) now
try to move the wheel to one side or the other as you try to turn the key
be sure not to break the key off in the lock...
HarryD 10-01-2010 04:28 PM
George
I asked my locksmith about Graphite. His response was that I was free to use it and he is looking forward to seeing me in few years to clean out the mess. He felt pretty strongly about TriFlow.
aigel 10-01-2010 10:00 PM
Harry,
There was no tri-flow 25 years ago when I learned about graphite. I am sure there are better products out there now, I am just saying oil based lubricants will bind to the dirt / dust you insert with the key every day. I used graphite on all my classic cars and it worked flawlessly for years.
George
na2ub 10-01-2010 10:57 PM
+1 on this info. When I rip the key out in a hurry, I tend to have a tough time unlocking the ignition. I came to the exact same conclusion ast 313green. Maybe some triflow would improve this?
HarryD 10-01-2010 11:35 PM
George:
No problem my friend. I was a graphite guy for a very long time.
dshepp806 10-02-2010 02:49 AM
Tri flow, for sure.
Aside,..when exiting the car, ensure the wheels are lined up straight ahead (no wheel pressure on the locking stuff)...it's just a habit of mine,...then remove the key and slightly rock the steering wheel L or R....no binds.
Your locksmith is correct.
dicklague 10-02-2010 08:43 AM
any luck with these solutions Remigio?
Quicksilver 10-03-2010 05:03 PM
On my car if it is locked and the steering is preloaded the key won't turn. I just move the wheel to release pressure on the lock and the key frees up.
I had a friend let me drive their SC and the key wouldn't move until I turned the wheel till the wheel lock kicked in.
remigio 10-03-2010 06:05 PM
reply to dicklague
quote "any luck with these solutions Remigio?"
don't know. on the road for 1-2 months; could strtch to three. at the mercy of former us army sgt now in school on whether he buys the triflow and try it on the car. thanks for all the advice guys.
remigio
Coach House 911 03-08-2011 01:36 AM
Any luck with this remigio?...
I am having the same difficulty it seems. When I put the key in the ignition it would not turn since the car last ran in Oct.
Tonight I jiggled the wheel left/right while finessing the key but its locked solid. Key comes out no problem -just won't turn.
Based on this forum the solution is Tri Flow?
l_turn9 02-09-2020 07:58 AM
re: using WD-40. FYI - Please remember WD is not a lubricant. It was developed years ago as a Water Displacing agent for the military - Air Force I believe - for one of their engines. But it is great at displacing moisture, there are many products that do a better job lubricating although WD will be slightly lubricative for a period following application.
Good luck with your P-Cars!
911 SLANT 02-09-2020 08:49 AM
I just had this happen to me a couple of times before I notice that my key only works one way. When it doesn't turn I flip the key and turn freely. No problem.
ian c2 02-09-2020 09:24 AM
There is also a Wd40 lubricant .now
l_turn9 02-09-2020 11:41 AM
Ian c2
re WD40 Lubricant. Good to know! Thanks!
So the trick here is to know what you need and buy accordingly.
Larry
ian c2 02-09-2020 02:52 PM
I’m not recommending it , just pointing out that it’s out there .
I’ve only ever used it at work once on a padlock . :D
l_turn9 02-10-2020 04:44 AM
Had this problem a few days ago - one day my key worked perfectly, the next day it refused to turn at all. After following the suggestions in this thread it now works great. I used brake cleaner sprayed into the keyhole (must use the tube) and worked the key in & out several times, wiping it each time - lots of black junk came off on my towel. A word of caution, make sure you have something on the knee pad, because the brake cleaner will leave light gray spots where it drips (BTDT) - I think I fixed the spots. After I cleaned the key cylinder I put a thin coating of a gun coating that is non-oily and now the key turns smoothly again. Helpful thread - Thx to all.
Flojo 02-10-2020 05:21 AM
Problem is: the cylinder is set horizontaly.
but it was fully lubed back then.
thus trying to clean it installed does not solve cleaning the gunk inside sitting top of the key.
spraying brake cleaner or WD40 will help cleaning the bits sitting bottom.
A proper clean will need to take it apart.
same issue for the door locks
Long Nose 01-03-2022 04:53 PM
OK, so it's crazy these days what lubricant works and what doesn't.
2010 Cayenne GTS - was having issues when I removed the key with the system staying on, i.e. not recognizing the key was out. Sprayed some WD40 into the mechanism, and its worked great since.
Electric Garage Door Opener with screw mechanism - used lithium grease to lubricate the screw - and the door actually seized up!!! Had to spray cans and cans of WD40 into the screw to flush all of the lithium grease out, door works fine now (phew!!).
1970 911 - Ignition key was a bit stiff, sounded like there was some sand or grit in the mechanism. Hit it with a shot of WD40 - lock seized! Won't turn at all now. Used compressed air to try and blow out the mechanism (computer cleaner can). Still nothing! Have tried two keys, and its seized. The steering wheels turn fine, the wheel lock doesn't seem to engage at all. Will try and use brake cleaner or something, and then I am not going to lube anything in my garage for a while (OK, we all know that's not true).
HarryD 01-03-2022 05:31 PM
Try TriFlow lubricant.
Their ad media should say Friends don’t let friends use WD40.
T77911S 01-04-2022 11:07 AM
push the key in a little harder while turning if its not the steering wheel.
my 930 does it sometimes.
