Carmagic.us
Here is what it looks like ![]() ![]() Here is what the light looks like ![]() ![]() Cheers
For BA7s Dash LED, and External Marker LED go to carmagic.us - Now Luftgekühlt Emblems |
Happiest when Tinkering
I just reread the specs this projector supports hi and lo beam in the controller supplied and has the ability to have both hi and low beam at the same time if desired. I dont think this would work right simply plugged into the back of a H-4 because the pattern on the lens would refract the light and give the wrong pattern it needs a clear lens to work right. These are D2S bulbs standard for a projector and the solenoid mechanism seems to be the standard method used to change beams in most cars. The way the controller works is it plugs into the stock harness plug and the hi/lo beam is triggered by voltage from the appropriate circuit. My plans appear to be sound the only variable here is the quality of the projector. I decided I am going to use 1/8 inch aluminum plate to make the bracket to mount the projector to.
" Porsche there is no substitute" I always liked that saying. Air cooled is the only way to go! 76 911 C.R.A.P. Gruppe #2 BIG time TURBO C.R.A.P. Bitz EFI/EDIS Now MegaSquirt 3 76 Blazer also restored by me |
Rothaus thats what I am talking about!
I wonder how this would look with the clear VW lense?
Sierra Madre Collection :: Bosch H4 Headlight Reflector, 911/912/930 (65-87) So, in concept, I could use the above bucket and one of these http://www2.cip1.com/ProductDetails.asp?ProductCode=VWC%2D111%2D941%2D1 15%2DH and get a pretty clean projector-ish look, no? Or would I still need the projector set up?
1983 SC - sold 2002 996 C4S - sold 1968 912 Last edited by mickey356; 10-04-2010 at 06:58 PM.. |
Rats!
I guess I need to ejamcate myself a bit more on all of this. I haven't taken a headlight apart yet to see what the bucket looks like inside, I was just assuming it was something like the one posted with the fog light/ head light combo on the yellow longhood. I'm hoping to get closer to the Singer headlight that has a chrome bucket AND the projector light with a clear lens. Are the stock buckets chromed inside? I figured I could modify the chrome bucket from Sierra with the projector to get teh "Singer look".
1983 SC - sold 2002 996 C4S - sold 1968 912 |
jeep community has some ideas and options.
i wonder how this look in our bucket... http://www.brightheadlights.com/JEEP-6024.JPG
1984 911 Carrera Coupe - 32C #73 - M64/05 1998 E36 M3 4dr 2006 Sienna 5dr - the hauler 2004 Lexus GX470 2010 Cannondale Caffeine II - Lefty |
i also wonder if i could slip this in with little scraping...
I had crappy sugar scoops so ANYthing was better, LOL. The H4 trims do look the part. My biggest issue was finishing the interior spaces. Essentially, I got Audi HID bi xenon projectors and ballasts off ebay (used from a wreck(, and fabbed them in. I added some fogs to fill the space and add some warmth. I'm adding 'fluting" to the clear lenses in all non pattern areas of the lenses to obscure the ability to see the interior. One issue that really pisses me off is when people mod their lights with cheap crappy bulbs and/or HID bulbs not designed for the reflector/ lens they get put into. NOT blinding other drivers was priority number 1 for me, and I think it should be for all of us. By using the Audi units, I knew that they were approved by all agencies that were important. I really like what the BMW lights in the truck look like and I know they are legit.
Jake Gulick, Black Rock, CT. '73 yellow 911E , & 2003 BMW M3 Cab. Ex: 84 Mazda RX-7 SCCA racer. did ok with it, set some records, won some races, but it wore out, LOL[/B] |
We have a kit I will try to post soon, HID 4500K very cool. William@knightrace.com
I drove his 944 turbo last night that had a simple bi-xenon bulb swap in standard Bosch H4 housings with fluted lenses and it was great. There was no issue with undesirable light pattern. The light pattern was just the same as with halogens but with xenon light (4300K) and high/ low beam combination. He bought the kit on ebay, it is a simple installation, and it is reversible. The kit is intended to be used this way and does not incorporate any "projector" housing. It is a bulb swap that includes a set of ballast/controllers. I think this is the kit he used. I can understand that some may want to convert the look of their headlights, but for those who like the classic H4 look, you can still do the bi-xenons and not be concerned about the light pattern with fluted lenses. This is what I will be doing in the near future. Regards, Chad
09 Cayenne GTS: GTS red, race car tow vehicle 86 Porsche Carrera, GP White- E Class PCA Club Race Car 71 Porsche 911T Targa, Silver, Sport seats, 2.7RS spec motor. 90 Porsche 928 S4 w/ 37K miles Grand Prix White/ Cashmere 73 Karmann Ghia Cabriolet, Black, 1776 Turbo, 250hp |
French Import
The results are awesome! Quote:
Gilles & Kathy Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road! ![]() 86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate |
If I'm reading all the info correctly I get this - a projector is a bulb/lens combo that on its own works together and directs the light properly, this set up would be ok to use a clear "protective" lens and the original trim ring.
The other option would be to use a sealed beam type with a clear "protective" lense like the OP used. I'm looking to get away from the fluted lens look (also would prefer to avoid the diamond pattern reflector used on the sealed beam) but want a very clean look inside the light, what is my best/most economical route? |
so does anyone have a night pic up against a wall to show the actual cutoff of the ebay setup?
Chad, that's interesting. HIDs have been used in projector setups (as have halogens) in many applications. Projectors are chosen because if the incredible beam control they have, while being able to provide cutoffs that comply with the strict regulations. Euro bi xenons comply with different counties regs with simple shutter changes.
To this point, I haven't seen (but I honestly haven't been looking either) any kits that have created HID bulbs that orient the filament (err...spark) exactly in the same location and orientation, as say an H4 filament. There vast majority of the kits are merely shoving something that sparks and has pretty colors in the general vicinity, and have no real concern for pattern or cutoff. (More has to be better!). If these do indeed put the actual light source in exactly the same location as the bulb they replace, with the same internal shielding (if there is any) then that's a huge step. When you get the kit can you provide side by side pictures if the H4 bulb next to the HID bulb? I still have to think that a projector setup will, in most cases, be superior to a fluted lens setup, but I'm no lighting engineer.
If you think it is ricer then you dont have to hook up the angel eyes I will reserve my opinion for when I see them and disconnect the outer light if I dont like it. But right now I am looking more at getting projectors theat will except D2S bulbs and use them instead of the ones that have the extra lights much like lateapex911 did I want a clean functional look. The only complete projector kits out there are these ones with the angel eyes in them.
I didn't realize the higher end BMW's have the "angel eyes" around their projectors.
another source of what appears to be quality parts all intended for retrofits. They didn't really have a lot of this when I was doing my set up
The Retrofit Source online: headlight upgrades for all applications
Carmagic.us
You can find more info here, tons and tons of HID
HiDplanet : The Official Automotive Lighting Forum
