-   -   911 Carrera Paint Code HELP!! (http://forums.pelicanparts.com/porsche-911-technical-forum/567393-911-carrera-paint-code-help.html)
hasaramat 10-01-2010 03:02 PM
I have a 1985 Carrera Cab that does not have a paint code tag in the drivers door jam. Did they put it in a different spot on this car? It looks like there has never been a tag in the jam (no rivet holes) and the car has not been painted. The color is that darker blue that sometimes looks purple in sunlight. Thanks for any help. Matt.http://forums.pelicanparts.com/uploa...1285974107.jpg
ZCAT3 10-01-2010 03:48 PM
Pop the hood and look near the front of the passenger sie wall. You may have to unsnap the carpet, but the paint code sticker should be there.
plumb4u2 10-01-2010 06:02 PM
on my 84 targa paint code is under the trunk lid...lift the hood look at fuse box drivers side then look straight up
86 911 Targa 10-01-2010 10:15 PM
Maybe Slate Blue, or Slate Blue Metalic.
http://forums.pelicanparts.com/uploa...1286000100.jpg
hesaputz 10-02-2010 01:47 AM
The common one for '85 is Prussian blue, 33x. It has the purpleish look.
Wil Ferch 10-02-2010 11:20 AM
Psngr fender/vertical/inner surface....snap off the carpet in that area.
See here as an example--->first pic, look right behind the 3 rubber plugs on the trunk's sidewall, visual sightline just under the top of the headlight ring--->
http://forums.pelicanparts.com/uploa...1286047151.jpg
Second image is detail enlargement--->
http://forums.pelicanparts.com/uploa...1286047205.jpg
