RSM-M491's Avatar
Headlight Lens Removal HELP!
Ok, I have the trim piece off, but now what? The lens is still tight to the car, what other screws do I remove to get the lens out?!
Thanks!
Rod
89 Carrera 3.2
1989 911 Targa M491
1980 Triumph TR8 (sold)
2006 BMW M3 (Interlagos Blue)
Old 10-01-2010, 06:13 PM
Oh Haha's Avatar
There SHOULD be one at the bottom of the chrome trim ring. Use a flat blade screwdriver to back it out and then you can lift the assembly out and up, away from the opening.
Pacific Blue
Wayne
Old 10-01-2010, 06:29 PM
Poor-sche Lover's Avatar
Once the trim ring has been removed, there should be four screws behind the headlight assembly that you need to remove. They are at about 2, 4, 8, and 10 o'clock. Make sure you don't accidentally try to remove the adjusting screws.
Alan
Past: '74 914 2.0, '82 911 SC Targa, '88 911 Cabriolet, '88 911 Cabriolet again
Present: '00 Boxster S
"Happiness is not around the next corner......happiness IS the next corner."
Old 10-01-2010, 07:25 PM
RSM-M491's Avatar
Ok, so how do I get the moisture out of the lens, I let them dry over night, but still have "drops" in the lens.... Any tips on that?
Thanks!
1989 911 Targa M491
Old 10-02-2010, 01:08 PM
The usual suggestion is to use a long stick (pliers, forceps, whatever), a small rag, and some rubbing alcohol, and swab it around in there. You have to be careful about not messing up that little metal reflector, but it's not that difficult. Good luck!
Alan
Old 10-02-2010, 01:18 PM
RSM-M491's Avatar
Ok, so I will ask the newbie question, why rubbing alchohol? I used Windex, and let is sit in the lens for a few hours, and then poured out all the Windex, lens looks good, but the moisture is the concern....
Thanks!
1989 911 Targa M491
Old 10-02-2010, 01:28 PM
Because windex doesn't evaporate as quickly as alcohol.
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 10-02-2010, 02:23 PM
