front end
Happy 4th everyone. I am having my 79 911 sc alined on Sat. I lowered the front end to 25.5 off the ground. My question is ,is it the same as standard or are the spec different. if so does where can I find them.
Bruce Andersons book has all the ride height settings.Make sure you have your car corner balanced when you have it aligned,changing the ride height effects the balance.
One important thing to do before you take it in is to remove those BIG 10 mm thick spacers at the top of the struts, beneath the strut bearing ... you will have to remove the 22 mm nut and compress the strut down to get them off!
------------------ Warren Hall 1973 911S Targa |
| All times are GMT -8. The time now is 08:07 AM. |
