Rec Counter under reading
Hi,
1983 911 SC 3.00, the rev counter is reading way too low, probably half what it should, it was working fine a few months ago, any ideas? Many thanks Stephen |
Just bumping this, any ideas anyone?
Holy smokes - three years almost between posts - you got some patience.
Not being a tachometer wizard, I would start with electrical connections. The CDI box feeds the tach. Permatune has a nice web page detailing the 6 pin connections. Make sure the tach wire is well connected. Even unplugging and re-plugging the harness can do wonders for skanky connections. Perma Tune High Performance Ignition Systems Get into the luggage compartment and push out the clock - into the passenger cabin. Then push out the speedo and tach. I don't remember if you need to start them from the luggage compartment and then finish the pull out in the passenger compartment. I do remember if you get the clock out it facilitates removal of the other gauges. Check all connections one at a time on the tach. Look for corrosion, etc. It has to be something simple |
| All times are GMT -8. The time now is 03:26 AM. |
