mojarra2929's Avatar
Help with strange hole
Do you guys know what is supposed to go through the hole you can see in the attached picture?
I´m talking about the hole between the two A/C lines. My car is a 911 carrera year 1985 with factory A/C.
Miguel
Last edited by mojarra2929; 10-03-2010 at 02:34 PM.. Reason: forgot to say something
Old 10-03-2010, 02:32 PM
Zeke's Avatar
There are a number of things that can go there, but the first one to mind is the washer reservoir hose to washer pump. I may have a battery overflow hose there.
Old 10-03-2010, 02:41 PM
brooklyn ny 11234
930 slant nose's Avatar
smugglers box
Old 10-03-2010, 03:01 PM
COL 911
COL 911's Avatar
On my '87 there was a solid rubber grommet installed on the hole in that location. After replacing my battery, I used that hole to extend my battery vent. I replaced the battery, extended the battery vent tube with similar dia. clear (surgical) tubing, and routing it through the grommet, which I pierced, to the outside. Access it from the inside just under the front battery 'tray'.
Beetle, Bimmers, Saabs, and finally...1987 Carrera
Old 10-03-2010, 05:02 PM
Originally Posted by 930 slant nose View Post
smugglers box
No, it's about 4 feet from the smuggler's box.
The hole (LF fender has been removed) is just below the battery.
Old 10-03-2010, 06:32 PM
j_mancini's Avatar
On my '82 that is where the headlight washer pump wires go.
John
1982 911SC Targa ~ Gulf Blue (gone but not forgotten)
Old 10-03-2010, 08:36 PM
