1987 911 Turbo ignition cut off relay
hi... i just pulled out part way my ignition relay part way on my 1987 911 turbo and found this connection please view photo... should one of the pins be exposed? thank you..
Old 09-04-2011, 11:25 AM
DSPTurtle's Avatar
Thats a locating pin. The four active leads are actually spades. You should be fine.
JB - BreitWerks
www.breitwerks.com
321-806-8664
Engine Rebuild & Restorations
Old 09-04-2011, 12:20 PM
damn crusty fuses though, and an overheated tab. check the front panel too.
206 637 4071
Old 09-04-2011, 08:08 PM
thank you DSPTurtle for the info... And Mr Walker you are right the fuses are pretty crusty and that tab has got very hot for some reason, you will be seeing the car soon.. thanks again..
Old 09-05-2011, 09:33 AM
