Air Flow Meter
I need a 1987 Air Flow Meter for my 1987 911 sc engine. Where is the best place with th best price to find one. My mechanic said I am due to replace it soon. Please Help!!
Old 10-07-2010, 04:51 PM
Crusty Conservative
silverc4s's Avatar
Do a search on 3.2 airflow meter here, many times they can be rebuilt. I think the most common problem is a wear on the resistance wiper surface, which can be moved around a bit.
There are also used parts places, like Partsheaven in Hayward, CA that can sell you a used one.
If you car is an 1987 model, it is a Carrera, not an SC, right? Good luck, post some pics and become part of the group here...
Bill
69 911 T Targa, 2.4E w/carbs (1985-2001)
70 911 S Coupe, 2nd owner (1989- 2015)
73 911 T Targa, 3.2 Motronic (2001- )
Old 10-07-2010, 04:56 PM
E Sully's Avatar
This link will give you a way to check your AFM with a 9v battery, and how to adjust the wipers if worn.
Air Flow Meter (AFM) - from "The 944 Motronic DME" by FR Wilk
Ed
1973.5 T
Old 10-07-2010, 05:02 PM
Hello and welcome. I had problems with a hesitation issue which was partially caused by my AFM. I did as mentioned above and cleaned it and adjusted the wiper arm. Between that and replacing the O2 sensor and cylinder head temp sensor it fixed my problem. I hope that helps.
Chris
Chris
95 993 C2
84 911 gone to to a new home
Old 10-07-2010, 06:41 PM
