-   -   2.4T Compression 80 x 6 - ok? (http://forums.pelicanparts.com/porsche-911-technical-forum/568745-2-4t-compression-80-x-6-ok.html)
porschecab 10-08-2010 01:48 PM
I know compression on 2.7, 3.0, and 3.2 motors, but unclear as to what a 1973 2.4T motor should be. The one available to me reads 80 across the board before putting carbs on. Is this acceptable?
Rot 911 10-08-2010 01:57 PM
Should be closer to 120, but maybe their gauge reads different. Or it could be an engine that is shot and needs a rebuild.
Mr9146 10-08-2010 02:24 PM
Does it run?
How does it run?
Has it been sitting idle for a long time?
When was the last time it ran?
If it runs and sounds decent, put a few miles on it and then adjust the valves. You may get a different reading.
porschecab 10-08-2010 02:47 PM
Yes, it does run. Sat for about 5 years. Run well? That I don't know. Thoughts?
BK911 10-08-2010 04:13 PM
80 is very low. My lawnmower is more than that. I would do a leakdown just to verify. If the 80 is accurate I would expect a leakdown to be over 20% and be VERY close to rebuild time.
My bet is closed throttle plates giving a low compression test.
Tyson Schmidt 10-08-2010 04:50 PM
Did you do the test with the throttle wide open?
With individual throttle bodies you have to have the throttle wide open to get a proper reading. And a fresh battery too.
Hladun 10-08-2010 06:39 PM
http://forums.pelicanparts.com/porsche-911-technical-forum/428453-compression-test-pressures.html
larrym 10-08-2010 07:36 PM
way too low
- culprits can be bad rings, not enuf pump strokes (6 needed ), closed throttle, weak cranking, or (unlikely) universally and equally leaking valves - a leakdown will tell a story , cold or otherwise
my 2.7 8.5 CR pumps 165 with solex cams - cool block - OAT = 85 at 2800 altitude (readings 2 weeks ago)
I had that engine dyno'd today - it makes 125 rear wheel HP and flat 112 torque curve from 2800 to 6500 rpm with webers and stock distributor curve
BK911 10-08-2010 08:09 PM
Larry I agree with everything you said. But more importantly, I LOVE your signature.
The older I get, the better I was. Just classic!!
larrym 10-09-2010 04:14 PM
Bruce Anderson writes in Performance Handbook 2 that a good 911 engine will show 130-170 psi
our guru Wayne Dempsy's book has a complete procedure outlined on page 14 and uses 150 as an example reading
