Fuel distributor sealing washers
Or crush washers. Anyone know where I can find the correct crush washers
for the fuel line banjo fittings and the fitting in the center of the fuel head that goes to the WUR? They are 3mm aluminum for the lines and the center WUR fitting is copper with a hair smaller inside diameter then the fuel line washers.
I bought some at a local motorcycle shop but they are a little off from what is on there. I don't want to have a fire..
Our host does not have them
McMaster Carr does not ether.
Silver 1980SC Euro coupe
Old 04-14-2011, 10:40 AM
I stock a large selection of such things. Send me an e-mail with OD & ID of what you need and I'll look.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 04-14-2011, 10:43 AM
Thanks Steve.
The injector line banjo fitting washers are OD =11.4 MM ID =8.25 MM
Thickness = 1 MM "used".
I will have to check the washer for the center of the fuel head to WUR fitting tonight.
Old 04-14-2011, 11:01 AM
