79 911 sc
Loose Head Bolts????
Looking for some input on why my head bolts wont stay tight. 79 sc, fresh rebuild upper and lower, ge60 cams, je piston with 9.5 cr, weber 40s. Studs are new dilivar by previous owner. This is the 2nd time they have come loose. Any thoughts would be appreciated. Thanks Bill
Old 10-09-2010, 07:32 AM
pete3799's Avatar
Threads stripped or pulled in the case?
Pete
79 911SC RoW
Old 10-09-2010, 08:11 AM
Bill,
Just to be clear, are you referring to loose head nuts or the studs???
Are you sure they used Dilavars in the rebuild?
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 10-09-2010, 09:11 AM
The solander should have been replaced with steel. Hopefully the threads in the case haven't been stripped. Are you setting them to the roper torque
Old 10-09-2010, 09:47 AM
Stupid auto correct. Solander Should say dilavar
Old 10-09-2010, 09:49 AM
moneymanager's Avatar
Mine loosened three times I think before finally staying tight. Check them frequently over the next year, they may fix themselves.
jhtaylor
santa barbara
74 911 coupe. 2.7 motor by Schneider Auto Santa Barbara. Case blueprinted, shuffle-pinned, boat-tailed by Competition Engineering. Elgin mod-S cams. J&E 9.5's. PMO's.
73 Targa (gone but not forgotten)
Old 10-09-2010, 12:58 PM
Dilavars stay tight, as do steel ones (unless improper anchored into the case).
ARP's and Raceware's do loosen over time as they do not expand at the same rate as the rest of the engine.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 10-09-2010, 02:00 PM
79 911 sc
They are dilavars and they seemed to be anchored correctly. I am attending a DE mon and tues I will check them after that and see if they are still at 24ft lbs. Thanks fot the input! Much appreciated.
Old 10-10-2010, 06:26 AM
