-   -   is there any way to fix 1974 (http://forums.pelicanparts.com/porsche-911-technical-forum/569071-there-any-way-fix-1974-a.html)
930 slant nose 10-10-2010 05:31 PM
leaky fuel accumulator leaks on bottom right by the little screw
thx in advance
Grady Clay 10-10-2010 06:30 PM
Some images will help.
Best,
Grady
James Brown 10-10-2010 06:32 PM
or get a new one prior to the fire.
930 slant nose 10-10-2010 07:17 PM
why then i could sell it for parts here and probably make more than the car is worth
930 slant nose 10-10-2010 07:20 PM
if you need an image then you probably cant help me because it never happened to you then its a stock accumulator that has a little screw on bottom and its leaking drops thru there
thx
crustychief 10-10-2010 07:28 PM
Yeah, Grady probably can't help you.
longhornchris04 10-10-2010 07:32 PM
The right way - replace the fuel accumulator...
The cheap way - take out the fuel accumulator and a seal up around where its leaking with a gasoline safe sealant. Gas is a great solvent... so I have not idea what you should use.
Personally I'd go with option 1. In either case, be ready for a fair amount of fuel to come out of the lines. I just did my fuel pump, accumulator, and filter, and there's an decent amount of fuel that stays in the system. Having a disposable container (water or soda bottle) to collect the fuel from the lines will help keep the mess down.
Also, while you are in there, change out the fuel filter.
LuftWaffle 10-10-2010 08:23 PM
If it is a stock accumulator (Bosch 0438170015) then there is no "little screw" - at least not on my 30K 2/74 car. Of course it may be different on the "930 slant nose" variant.....:rolleyes: Give us some details and we'll be glad to help you. -John
Stevepro 10-10-2010 10:00 PM
Mine also recently developed a leak in the same location. I removed the small screw, cleaned up the threads and replaced the screw with a little 3M liquid pipe thread sealant. I made sure the screw was well tightened. The leak has been fixed.
I also have a pressure accumulator from an 81SC which has a hose connection at the bottom (in place of the small screw) which connects th the fuel return line to the fuel tank. I understand that this is to drain any fuel that escapes past the diaphram/spring? in the base of the accumulator.
I guess there is a possibility that the diaphram in your (and my) '74 accumulator may have developed a leak past the diaphram into the base area.
I am going to remove mine, remove the small screw, seal the normal outlet and pressurize the inlet and see if pressure is escaping past the diaphram. If so it will be time to replace.
Good Luck - Steve
carrera turbo 10-10-2010 10:48 PM
930slantnose
this is why images might help!
ed
Joe Bob 10-10-2010 10:49 PM
"Use the search function.....%^)"
Paraphrased...
paulgtr
just me
930 slant nose 10-11-2010 06:38 AM
steve you seem to know what im talking about when you took out the screw was there any rust or just gas.and when you put back did you put back the same screw
thx mike
930 slant nose 10-11-2010 06:41 AM
this is in a 1974 911 just like the ad reads and the part number is 0438170015 and yes it does have a little screw look up on google and you will see it
thx i think ill just clean it with a little air and carb cleaner and take steves advice
thxfor all your help
930 slant nose 10-11-2010 06:43 AM
long horn why would you change all those things was your car having trouble starting or something
longhornchris04 10-11-2010 07:08 AM
Fuel pump was definitely bad... bypassing the relay would only cause it to intermittently work, so that had to go.
Fuel accumulator was old, and easy to deal with at the same time.
Fuel filter because its supposed to be done every 6k miles, its cheap, and I was in there.
930 slant nose 10-11-2010 07:08 AM
heres the image 1973 1974 1975 1976<a href="http://tinypic.com?ref=28rgu3r" target="_blank"><img src="http://i51.tinypic.com/28rgu3r.jpg" border="0" alt="Image and video hosting by TinyPic"></a>
930 slant nose 10-11-2010 07:09 AM
oh ok was it hard starting
JeremyD 10-11-2010 07:51 AM
Actually part number is 477-209-083-M14
usually if it leaks you are also having a problem with warm/hot start.
it's a $117 part - you can probably thank ethanol for the break down in the diaphram.
Carry a fire extinguisher, I would not transport anybody you really care about. Where the accumulator is - makes it easy for gas to pool - then drip on the heat exchangers - then the excitement can start.
scottb 10-11-2010 09:38 AM
Um, do you have any idea who Grady Clay is and what he knows about our cars? As the old cliche goes, he has no doubt forgotten more about these cars than many of us will ever know.
You might consider apologizing for dissing him in a very public forum, to which he contributes regularly and with great skill.
Stevepro 10-11-2010 11:35 AM
Hi Mike. Yes I put the same screw back again. The screw was rusty but cleaned up OK. I screwed it up as tight as I could with the sealant and it has been leak free for a few months. As indicated before this may be indicating a further problem and as others have recommended, replacement might be cheap insurance. - Steve
