What size tubing to match 1 5/8 header?
I am installing 1 5/8 headers onto a basically stock 3.2 motor.
I will be fabricating a dual exhaust system, with 2 cats and mufflers. I plan to use magnaflow components. So what size tubing should I use to match the header? TIA |
How about 1.675"?
you should use 2" from the flange back on both sides. This is what is typically used
| All times are GMT -8. The time now is 03:25 PM. |
