wire connector
does anyone have a chart ,or where to get wire diagram for the 1976 911 engine left hand side 14 pin connector, I have the waterfall type diagram, but I can not figure it out thanks to anyone who could help. norm
Here's one for a 1974. I matches my 1975, and may be the same or close to yours.
T 14 2.7 (74) 1 yellow / starter 50 2 green / only used with sportomatic runs behind the instrument for the overheat idiot light 3 green - black / Oil temperature Instrument 4 green - red / Oil pressure Instrument 5 green - yellow ( depends on year ) / from ign. to back up light switch 6 gray - black ( depends on year ) / back up light switch to lights 7 8 9 black - purple / to tach 10 11 blue / alternator control light 61 ( or D+ ) 12 brown / to Regulator D- 13 black / to Regulator DF 14 red / source from alternator 30 or B+
Rex 1975 911s and 2012 Range Rover Sport HSE 1995 BMW R1100RS, 1948 Harley FL |
14-pin connector for '76 S.........
Norm,
I have the 14-pin connector charts for '76 , '77S, & SC's. Please send reply to atd911@hotmail.com and will forward the chart to you. BTW, '76 and '77 have different wiring diagram but many similarities. Tony |
nssnorm.
did you ever get the wiring diagram from me?
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
