-   -   Is this the Turbo Boost Sending Unit ? (http://forums.pelicanparts.com/porsche-911-technical-forum/56930-turbo-boost-sending-unit.html)
rboylan 01-15-2002 11:32 AM
1 Attachment(s)
Please see the pic. and let me know if I'm correct. Thank you.
Dave Bouzaglou 01-15-2002 11:50 AM
Rich
The item you are looking at is the fuel pump boost limit switch. It will shut down the fuel pumps whenever it gets close to one bar. Ground the wire to the manifold if you are running more than .9 bar. Leave the switch disconnected.
The boost sensor is the one that is encapsulated with a red silcone jacket and is about 1 3/4" in diameter. It located more centrally on the same manifold.
