Bosch CDI
Hello everyone.
I've heard and read few times that cdi's transfo works at 3KHz. Today using an oscilloscope I found it does over 4KHz at 14v input and only at ~3KHz at 4-9v of input. Is that ok? Thanks for your help |
yes
Than you
What is most important is that the DC-DC inverter be able to charge THE capacitor to at least 300 volts in the <3 milliseconds between plug firings at 7200 RPM. Last edited by wwest; 10-13-2010 at 12:40 PM.. |
I typically see around 3.6kHz at rest and yes the frequency shifts slightly with varying supply voltage but not to above 4kHz. And once the box is loaded up (running at 6k RPM) the inital run-in is at a slightly higher frequency.
If the box is damaged (shorted SCR or coil connected and shorted capacitor) the frequency changes to something above 4kHz because the DC/DC converter now works against a dead short. Once you reduce the supply voltage it comes back to the 3.5 kHz. You might have a damaged box if that is the case with yours. Ingo
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430 I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!! How about a NoBadDays DualChip for 964 or '95 993 |
