Banging in the front end
I have a 1977 911S.
Someone along its ownership put nylon bushings up front. Its not a squeak but a banging/rattling. Its not loose. The mechanic is putting the car up on the hoist tomorrow. What could possibly be causing the banging? |
Loose strut insert?
What Pete said or if the bushings were not fitted properly, they may be binding.
I've seen plastic bushings that seized up and eventually twisted the front mounts out of the front suspension pan. |
I second the posters above. This is much less severe than banging in the rear end.....
No help here, I know... |
Will have it checked.
I cant imagine it being a undefinable. |
I 2nd pete3799, I had a similar problem and my front strut inserts were loose.
Steve 73 911T MFI Coupe, Aubergine |
Check the sway bar bushings.
and make sure the sway bar mounts havnt broken loose
Okay, this is the story.
The A-arms rusted and created a 1/10th gap with the nylon bushing. So, the shop found a nice pair at a salvage yard and put in some stock bushings.......all is tight again. |
| All times are GMT -8. The time now is 08:41 AM. |
