Date stamp on crankcase?
Whereabouts is the date stamp (year) on the crankcase? Can it be seen while the engine is still in the car?
Old 10-12-2010, 01:42 PM
You don't mention which car or series you are interested-in.
There is no "date" stamp as such....you usually look for an engine "type" number....like 930/21....and then find the serial number, like 64EXXXXXX.
The combination of these 2 numbers...cross referenced against known text books and tech/spec books....will determine the model and year of car for which it was intended. Do a search on engine type numbers and serial numbers.
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 10-12-2010, 02:04 PM
djpateman's Avatar
The easiest identifier is the engine serial # on the right side of the fan support. From 1968 on the third digit is the year. There are casting dates on the case halves, but these are generally under the pulley. If you have an un-numbered case (replacement) then the casting part #'s on each case half will be a guide (L 901.101.101.xx & R 901.101.102.xx)
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info
Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s
Addicted since 1975
Old 10-12-2010, 02:23 PM
I meant like this:
(not my pic).
Whereabouts is it? Can it be seen while the engine is still in the car?
Old 10-12-2010, 04:03 PM
Ive only seen it on the sand cast aluminum cases
Bruce
Old 10-12-2010, 04:07 PM
djpateman's Avatar
This shows the locations on the aluminum case:
Addicted since 1975
Old 10-12-2010, 06:50 PM
djpateman's Avatar
Magnesium case date code is different, not certain of location:
Addicted since 1975
Old 10-12-2010, 07:06 PM
djpateman's Avatar
Found a location shot; this might be able to be seen while installed:
Addicted since 1975
Old 10-12-2010, 07:21 PM
Old 10-13-2010, 06:15 AM
