Question Harness Shielding Fix?
I've got the engine/transmission out and I'm looking at the harness coming up the right side of the transmission tunnel. The covering/shielding rubber is cracked and separating. Has anyone come up with a fix for this cover? I wouldn't think it would be a replacement part.
...or should I just not worry about it?
Dave
'75 911s Coupe
Old 10-14-2010, 06:21 PM
DW SD's Avatar
buy some bulk heat shrink tubing, probably 1 to 1 1/2" in diameter and replace. it was there for a reason. a 20' spool should do it.
Doug
1971 RSR - interpretation
Old 10-14-2010, 08:00 PM
