-   -   Highbeam/lowbeam malfunction (http://forums.pelicanparts.com/porsche-911-technical-forum/569969-highbeam-lowbeam-malfunction.html)
SJMporscheguy 10-15-2010 01:23 PM
Have '86 930 with hi/lo beam issues. About a year ago every time I put turn signal on to turn headlights would go from low beam to high beam after straightening out. Put a new steering wheel in this year and while steering assembly apart checked the turn signal/ hi-low beam operation. Everything worked fine after repeated checks. Re-installed wheel and everything still was working fine (in garage setting). Drove car several times and upon going thru signaling/turning operation a number of times, the turn operation would put me into hi-beam mode. Very difficult getting back to low beam mode. What is wrong and how do I correct. Can email me at smarlow@nycap.rr.com and respond to this forum both if not an inconvenience. Appreciate any help with this pain in the butt problem. Thanks
DonMo 10-15-2010 01:29 PM
Easy fix, see this link for the fix.
86 911 Targa 10-15-2010 01:31 PM
There are several good posts on this subject.
You might want to do a search-Turn signal stalk.
Also, there is an excellent post on cleaning/adjusting the contacts.
Another thought is to install some headlight relays.
Good luck,
Gerry
wwest 10-15-2010 03:34 PM
In the future don't let the 2-3-4 year old play behind the stearing wheel....
